11-27-2023
07:33 AM
- Mute
- Permalink
- Report
11-27-2023
07:33 AM
From the introduction of the new arrange method, I am not able to keep the machining setup to the pieces in the arrangement.
Each time I make a little modify in the model, the setup loose the bodies or components selected and I need to reselect the model of the setup and consequently each line in each machining that are not automatic.
The result is a lot of time waste and the impossibility to use it anymore.
I try to select the bodies, the components, the arrangements etc. nothing seems to change.
Fusion
