- Mute
- Permalink
- Report
I second the idea of having a feature where one can apply a material, say 6061 aluminum to a body or component, then when it comes time to CAM, I select the tool and the initial feeds and speeds are set based on the material. Since there are a zillion different materials in the design space perhaps you should add a feature that if I apply "6061" to my part, that will assign the "6061" feeds and speeds for each particular tool. Maybe even add the ability to create custom materials which are then able to be linked to tools. For example, mostly everything I create CAM for is wood. Wood is woefully under represented in Fusion 360. I have to manually tweaky for each tool, but it would sure be nice to be able to select a black walnut material and have it automatically apply the feeds and speeds for that material to all of my tools. I'm sure you see where I'm going here.
And I second the motion for having a built in feeds and speeds calculator that maybe gives an option to choose how aggressive you want to be with the cut. Just spit balling here.
Tyler
Fusion
