You can also try out the Haas NGC w/ axis post. Most things should be the same.
My post has
case COMMAND_LOCK_MULTI_AXIS:
if (machineConfiguration.isMultiAxisConfiguration() && (machineConfiguration.getNumberOfAxes() >= 4)) {
writeBlock(operationNeedsSafeWorkPlane ? "/" : "", mFormat.format(10)); // lock 4th-axis motion
return;
case COMMAND_UNLOCK_MULTI_AXIS:
writeBlock(operationNeedsSafeWorkPlane ? "/" : "", mFormat.format(11)); // unlock 4th-axis motion
Please click "Accept Solution" if what I wrote solved your issue!
