boyd.sofield
884 Views, 14 Replies
Need a 4th Axis Post for a DIY Machine with Mach 4
I've read a lot of threads and seem to only come up with posts and info about posts for machines that are manufactured. I have a home built router and want to run a 4th axis. Ive been looking at many threads on how to edit a post to suit but not being a coder am not having much success.
Wondering how I go about getting hold of a Mach 4 Post that will publish a program for my 4th Axis. I cant afford the machining extension but I do want to use the wrap and indexing options.
I also need to set it to rotate in the Y Axis not the normal X
An alternative is pointing me in the direction of a good page I use to help me make the edits I need too on the original Mach 4 Mill post. But I have not had much success in the past.
