jgaertner
1015 Views, 4 Replies
Unable to drill holes in corner of a pocket? No tool path generated?
Hello Forum,
I want to drill four   .125" diameter holes into a piece of aluminum PRIOR to milling out the pocket. I am doing this so I can drop a die stamp into this holder and be able to keep the sharp corners on the small rectangular dies. For some reason Fusion will not generate a tool path? I would drill the four corners, then mill the pocket.
Any ideas? It gives the error message:
Warning: Cylindrical face is opposite to tool's orientation!
Warning: No holes to drill.
