- Mute
- Permalink
- Report
Hello Forum,
I want to drill four .125" diameter holes into a piece of aluminum PRIOR to milling out the pocket. I am doing this so I can drop a die stamp into this holder and be able to keep the sharp corners on the small rectangular dies. For some reason Fusion will not generate a tool path? I would drill the four corners, then mill the pocket.
Any ideas? It gives the error message:
Warning: Cylindrical face is opposite to tool's orientation!
Warning: No holes to drill.
- Mute
- Permalink
- Report
delete the chamfers, or select points, not faces
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
New problem now, Spot Select worked but the drill holes are not the full depth so I get a collision RED indication on my sim and there would be no deep becking so the 1/8" drill bit is likely to break off! Any ideas ?
Fusion
