08-22-2023
09:26 AM
- Mute
- Permalink
- Report
08-22-2023
09:26 AM
I'm making 32 panels out of 10mm coroplast to hold 12 mm LED bulbs. The hole size it critical to hold the bulbs so I can't change the diameter. I've played with reducing the minimum radii, maximum radii, etc to no avail. The problem may be related to the center lines of the pockets not all being perpendicular to the WCS. The pockets are in a nested pattern created from nesting in advanced manufacturing. There can be literally be 1000 pockets in a Nest. I've attached the files that will help show my problem. I'm falling behind schedule, the machine is loaded with material and waiting for me to finish.
Fusion
