daniele_spagli
443 Views, 6 Replies
Side horizontal drills
Hi, I am struggling with the problem of horizontal drilling from slot of time and I am still not able to find s practical solution.
My machine have a set of side horizontal drill from back, front, right and left. The drills have a specific tool name but each time I need to select the correct direction for each tool instead of simply say that each tool correspond to an axis of the current wcs.
I wold like also to do a template where to save this informations but the template is not able to save any direction, can only save if I check the invert axis in the tool direction (that's a little weird but us ok).
I am sure that I am not the only one with this kind of problem, how have you solved it?
