a.laasW8M6T
in reply to: SGoldthwaite
Hi
the easiest option is to use 2D trace, set the compensation to left:
You may need to play around with the axial offset to get it to cut how you want.
Another option if you have the Machining extension is Advanced Swarf set to 3 axis mode. Not sure why but it doesn't quite do it in one continuous path
I have included both options in the attached file, but trace will most likely be what you want
