08-01-2023
01:25 AM
- Mute
- Permalink
- Report
08-01-2023
01:25 AM
Bug report on update for 01/08/23 - CAM turning Radi issue
Using Fusion this morning there was a latest update available. Following the update I finalised programming of a part.
Importantly for me, our drillhole in a turned part is 16mm. When then opening out the hold with a boring bar, due to the size of the boring bar (min bore) I set the clearance and inner radius on the Radii tab to diameter - 16mm.
Well, since the update, if you now open the same program from another user account, it resets those settings without even touching the tooling.
Today, this resulted in breaking the carbide boring bar. We've had to now to introduce an every time check, but between accounts, it now resets this setting every time.
Would be awesome if that could get fixed pretty soon
Fusion
