07-21-2023
04:19 AM
- Mute
- Permalink
- Report
07-21-2023
04:19 AM
I fully understand that now, I guess the question is why you would need this? If you already found your part g54, just run off that. If it's a repeat part, you can just save that translation distance from your known vice corner.
I get you want to use the g59 to save time, but use g54 to be able to read the code "normally". In that case I'd just use a translation amount or decide if 2 minutes of finding g54 or being able to read code without math is worth more to you or the shop.
Please click "Accept Solution" if what I wrote solved your issue!
Fusion
