07-15-2023
04:41 AM
- Mute
- Permalink
- Report
07-15-2023
04:41 AM
Looking at your toolpaths, using spiral seems a bit odd. I'd use a pocketing op, see attached file. As you had no ramp in the spiral toolpath, I've set the ramp quite steep in the pocket op. Are you going to finish the pocket with a flat bottom cutter at some point?
This is the pocket toolpath, it has the same 0.5mm stock to leave you had in the spiral op.
Mark Hughes
Owner, Hughes Tooling
Fusion
