arna_mould
184 Views, 1 Reply
Help, postprocessor for DMU 100 T since 2002 , 3 axes
Hello, I recently started using fusion 360 and I'm facing a processing problem
I installed the millplus postprocessor that I found in the library, but unfortunately it doesn't work, there are g codes that the machine doesn't recognize.
The software of the machine is Millplus and when it loads it says something like tnc 246268 01.
Thank you very much
