AchimN
in reply to: bjw9EQBR
Hello @bjw9EQBR ,
I am pretty sure that you get this error because your Fusion installation is outdated but the postprocessor you are using does require Fusion to be updated to the latest version.
In detail, the latest Shopsabre postprocessor does require as a minumum the postprocessor kernel version 45917 and there is a good chance that your outdated Fusion is using an older version.
You can either try to get your Fusion updated so that it has the latest postprocessor kernel or you can use the previous version of the Shopsabre postprocessor which you can download here:
https://cam.autodesk.com/hsmposts?p=shopsabre
More information about post kernel/post script file versions:
https://forums.autodesk.com/t5/hsm-post-processor-forum/need-help-with-error-the-post-configuration-...
Achim.N
Principal Technology Consultant
