seth.madore
in reply to: bjw9EQBR
What post processor are you using, and can you share your Fusion file? (it may be related to a toolpath setting)
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
As for the "Update Failed", you can click here:
If that doesn't solve it, you'll likely need to run the Fusion Service Utility
(likely not related to the issue you're seeing, but it's best to resolve this issue)
Seth Madore
