seth.madore
in reply to: VisualConduct
Well, it all depends on what you're doing. Is this two sides of the same part or a left panel and right panel?
If it's the former, you likely don't need the 2D Contour toolpath again. The question arises, however; how are you going to locate the part and establish your WCS at your machine? Easy enough task if you have a fixture to drop it into, not so easy if the part is just roughly located on your table.
Seth Madore
