r.blahynka
in reply to: seth.madore
Aha, I did poke around on that tab, but I only highlighted the first instance in blue and then tried posting, which of course posted the whole pattern again. Didn't notice the function of those three bars. It's a usable solution, thanks for the tip @Laurens-3DTechDraw .
The problem with always simulating the full pattern can be "solved" by using "preserve order" in the pattern, and while the whole pattern is still simulated, you can just watch the first instance. If however I have operations nestled in different patterns (or even stock configurations), this will not help and cherrypicking operations from different patterns results in ALL the connected patterns being simulated and me having to find the specific operations I am interested in within the timeline. Also, due to this I can't check the estimated duration of a specific operation because I only get the overall duration of the pattern(s). It's pretty inconvenient and though I understand it may have underlying reasons in the code, I also find it hard to believe this couldn't be made to work more intuitively.
Anyway, thanks for considering
