- Mute
- Permalink
- Report
I notice when setting a user default that the fixed size box and relative size box use the same default setting for rounding up. I'd like to use my Fixed Size rounding up with 10mm and my Relative with 1mm.
Is this intentional or a little bug that needs to be smashed?
- Mute
- Permalink
- Report
Hi @Anonymous
I think this is kind of by design that both fixed and relative size box have the same default setting.
If you want to set different 'Round up to nearest' default values for fixed and relative size boxes respectively, you could put this expression : (job_stockMode!='fixedbox')? 1: 10 into the expression dialog of "Round up to nearest" parameter. This expression can give you 10mm rounding up value for fixed size box and 1mm for relative size box and other types. Hope this could help.
Kechao
Fusion
