nkidric
397 Views, 5 Replies
Chamfering with a Face mill with 45 degree cutters
i wanted to chamfer a large chamfer and wanted to try to do it with a face mill with 45 degree cutters (as it has 4 cutters and its 63mm in diameter i though it could be better as the 8mm Chamfer mill. But Fusion wont generate a tool path. I tryed with Tappered Mill and it also wont generate... Any sugestions?
Thanks.
Nejc
seth.madore
in reply to: nkidric
I would create this as a very large and squat chamfer mill.
Seth Madore
nkidric
in reply to: seth.madore
Thanks, yes that is working, it must be only a little tweaked with the diameter settings, as the diameter of the side of the tool is bigger  (where the 45 degree is).
RobertCMLF
I am creating a 3/8" chamfer and using a large squat face mill, as recommended previously.
I know the tool does not have a large enough cutting face to make it in one pass but will need probably 2 or three to get the full depth in both axes.
When I select the path and make my settings, I get a message that the defined chamfer is too large for the tool I have defined.
Now, I am new to Fusion 360 so could use suggestions.
a.laasW8M6T
You will need to setup a tool as a taper endmill
Then in 2D Contour you can do multiple depths of cut and the tool will step down the chamfered face
example attached, you will need to define the tool to match the dimensions of the one you have
RobertCMLF
in reply to: a.laasW8M6T
I was headed that direction with the 2D Contour and am able to use it with both of the tools.
I was struggling with the 2D Chamfer and just to accept that I wasn't going to be able to make it work.
I appreciate the quick response. It was a great confirmation that I was on the right track.
