eldavid0000
in reply to: eldavid0000
I was able to find something called "optimal load" and reduce this from 0.2 to 0.1.  That got rid of the error message, but I still don't know where the cusp parameter is or exactly understand what the error is about.
I did initially put "optimal load" to 1mm and it warned me that it needs to be less than the cutter diameter (makes sense, and as a tiny tipped tapered ball endmill as I specified it thinks it's even smaller than 1mm).
