serge.quiblier
in reply to: Danvil9226
Hi @Danvil9226
Open your post with a text editor.
Search for the startSpindle function.
Inside the startSpindle function, in the branch outputting the G97 command, we can change the code.
Piece of code before the change :
  if (getSpindle(true) == SPINDLE_SECONDARY) {
    writeBlock(
      spindleMode,
      sOutput.format(_spindleSpeed),
      spindleDir
  } else {
    writeBlock(
      spindleMode,
      spindleDir
Let's add some logic for gradually speed up the spindle.
After the change, the same piece of code is now:
.  if (getSpindle(true) == SPINDLE_SECONDARY) {
    writeBlock(
      spindleMode,
      spindleDir
  } else {
    var startSpindleSpeed = 300;
    var spindleIncrement = 100;
    var tempSpindleSpeed = startSpindleSpeed;
    while (tempSpindleSpeed < _spindleSpeed+spindleIncrement) {
      writeBlock(
        spindleMode,
        sOutput.format(tempSpindleSpeed),
        spindleDir
      writeBlock(gFormat.format(4), "P" + milliFormat.format(1000));
      tempSpindleSpeed +=spindleIncrement;
    writeBlock(
      spindleMode,
      spindleDir
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
