Danvil9226
in reply to: Danvil9226
/** Output block to do safe retract and/or move to home position. */
var XZ = 4;
function writeRetract() {
var words = []; // store all retracted axes in an array
var singleLineRetract = false;
var retractAxes = []; // axes to retract
var method = getProperty("safePositionMethod");
// define home positions
var _xHome;
var _yHome;
var _zHome;
if (method == "G28") {
_xHome = toPreciseUnit(0, MM);
_yHome = toPreciseUnit(0, MM);
_zHome = toPreciseUnit(0, MM);
} else {
_xHome = machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : getProperty("homePositionX");
_yHome = machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : toPreciseUnit(0, MM);
_zHome = machineConfiguration.getRetractPlane() != 0 ? machineConfiguration.getRetractPlane() : getProperty("homePositionZ");
Thanks for the response Serge!
Above is my post what should I remove.
I tried deleting and keeping as you suggested but kept getting invalid post
