04-20-2023
08:17 AM
- Mute
- Permalink
- Report
04-20-2023
08:17 AM
Hi @Danvil9226
It's because of the default behavior in the post.
When using G28, it will by default uses Z0 X0 always.
If you edit the post with a text editor, and serach for the function writeRetract, you can this this code piece:
if (method == "G28") {
_xHome = toPreciseUnit(0, MM);
_yHome = toPreciseUnit(0, MM);
_zHome = toPreciseUnit(0, MM);
} else {
_xHome = machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : getProperty("homePositionX");
_yHome = machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : toPreciseUnit(0, MM);
_zHome = machineConfiguration.getRetractPlane() != 0 ? machineConfiguration.getRetractPlane() : getProperty("homePositionZ");
That means G28 is always X0 Y0 Z0.
You can replace all the code to this simpler version, allowing to define your home position in the properties and use it.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Fusion
