HughesTooling
in reply to: WillL84
@WillL84  I have a couple of 3 axis Prototrack machines and I use the Prototrack GCD post, can you import gcd files with your control?
Using this post the code comes out like this. Not sure how your control will react to the Z moves but might be worth a try.
(1001.GCD)
(GENERATED BY FUSION 360 CAM *2.0.15509)
(FRIDAY, APRIL 07, 2023 133107)
(MACHINE)
(  VENDOR XYZ3500MILL)
(  MODEL 3500BEDMILL)
(  DESCRIPTION 3500PROTOTRAK MILL)
(T09  D=8.1 CR=0. TAPER=118DEG - ZMIN=-32.433 - DRILL)
N1 G90 G94 G17
N2 G21
(DRILL16 2)
N3 M09
N4 T09 M06
N5 S539 M03
N6 G54
N7 M08
N8 M334
N9 G61
N10 G00 X35. Y101.
N11 Z15.
N12 G00 Z5.
N13 G98 G82 X35. Y101. Z-32.433 R5. P3000 F65.
N14 X-35.
N15 Y-101.
N16 X35.
N17 G80
N18 Z15.
N19 M09
N20 M30
Mark
Mark Hughes
Owner, Hughes Tooling
