WillL84
in reply to: HughesTooling
The post puts out an MX2 file which the control then loads. I don't do any gcode on the machine itself. If I were to program that by hand on the control it'd say "set Z" at every hole position and this code does do that.
It's just after I drill the hole and hit go to move to the next one it goes to the origin then says "set x" again then I hit go again and it goes to the next hole. If I take out those lines with the Z depths manually before loading the code into the SMX control it won't do that.
Windows 11 Pro 64-bit
Inventor 2024 Pro (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
