- Mute
- Permalink
- Report
@WillL84 You're using a conversational post but the files you shared are G code, is that an intermediary file or does the control just give you a conversational dialog when you edit the code?
Can you program the machine manually? What does the code look like if done at the machine?
I don't have a 2 axis protack so not sure about that but I have a couple of old EZtraks. What seems odd is how do you know what Z depth to use? With the EZTraks you program your Z depths and you are prompted to set the Z to the correct depth, milling or drilling. Can you do this on a 2 axis Prototrak?
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
