WillL84
in reply to: HughesTooling
Ok I looked into that. By default the checkbox for "Use Z axis" is unchecked. I checked it and posted then unchecked it and posted again and they're both identical when it comes to having the Z values in the drilling section. There's no Z values in the contour section though but seemingly only for the start heights. There's still Z locations for the contour paths though, just not as many. Haven't spent a ton of time to see what the differences are - maybe the feed heights are taken out?
I tried to attach the gcode files but it says it doesn't allow attaching .mx2 files.
Edit - changed them from .mx2 to .txt
Windows 11 Pro 64-bit
Inventor 2024 Pro (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
