constantin3x
in reply to: DarthBane55
Not quite, I tried your code however it returns the same thing, that is the file name and the Fusion version number.
Probably because as soon as you upload a third part model, i.e. STEP or .PRT it creates its own file and associates that?
Instead of the actual file name I am looking for the filename which the solid model was imported from. so for example, on the left view panel, when you expand the version list, the very first version shows from which file this was imported from.
Trying your code returns POSTED FROM=222-091-pcb-base v19 which was the last Fusion file version, not the imported model one's.
