HughesTooling
in reply to: kieran.gill
Flat toolpath cutting air! I've notice when facing from outside to in all material is removed before the end of the toolpath and you end up cutting air. I've noticed this with other toolpaths as well, the toolpath below works fine if you start in the centre and cut out but from outside in not so good.
I've attached the file.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
