jambrozy
442 Views, 2 Replies
Tool Orientation - changing the starting point which gcode is generated
Hello Fusion Team,
I created a machining point from the central hole, I would like to move the X, Y, Z point to the bottom hole (G3/8") - in gcode it is the G52 function - and make a machining path from this point (tool orientation 2 photo), unfortunately the generated code is the coordinates of center hole (photo tool orientation 1). Does anyone have a solution to this problem?
Thanks in advance, greetings from Poland! David.
