03-21-2023
09:05 AM
- Mute
- Permalink
- Report
03-21-2023
09:05 AM
Thank you again for the clarification. I used the NYC CNC 'thread mill calculator' spreadsheet to determine a modified PDO. Just to further clarify then, if for example I purposely choose one stepover that is less than half the radial depth of cut required, then F360 will use the remaining depth of cut for the final pass? I ask because would this not be a way of getting/forcing at least two different radial cuts/stepovers (the first larger, the last smaller) - which is the goal and the main problem I was trying to solve.
Fusion
