hlefkowicz1
199 Views, 1 Reply
Unable to move Fusion 360 - Generated tabs
Hello!
Fusion generated some tabs for me, but they're in the wrong place. Is there anyway to move them? I can move the 'points' tabs that are manual with shift + click, but that doesn't work on the generated ones. The fusion generated tabs also have no 'tab points' which I think may be the reason you can't touch them.
seth.madore
in reply to: hlefkowicz1
Could you share an example of what you're seeing, or perhaps the file itself?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Tabs are generated automatically, based on Distance or Number of Tabs. If you'd prefer to just set your own tabs, set the "Number of Tabs" to zero and click "Manual Tabs" to start selecting where you want them
Seth Madore
