03-06-2023
01:16 AM
- Mute
- Permalink
- Report
03-06-2023
01:16 AM
Thanks for the feedback @wstoneandsons . Much appreciated. Glad your seeing improvements over Horizontal
As you have pointed out, Flat has a number of benefits over Horizontal but there is a couple of things you can do apart from loosing the tolerance of course which will have the largest impact.
You could also try lowering the smoothing deviation from 10%(default) to 0-5%. This will likely decrease code size by having less points around the inner cut areas.
Play with these two settings until your happy with the toolpath and the output code.
Kieran
Kieran Gill
Technical Consultant
Fusion
