engineguy
in reply to: lukeb9RLN
@lukeb9RLN
Had a quick look at your files and I don`t see anything in your G Code that would cause the CNC to make the moves shown, it could possibly be the settings at the Machine and not within Fusion.
If your setup at the Machine is incorrect in that you have the Machine Zero and the Part Zero mixed up then those G28 lines of code would pretty much do exactly what you have, try it without the G28 commands and see what happens, carefully :slightly_smiling_face: :slightly_smiling_face:
