Bunga777
in reply to: dmac252a
Accessibility analysis shows that this red area cannot be processed from the current processing direction.
If we take that into account and process as much as possible, Scallop may be the easy way to go. 
A small-diameter ball end mill was selected to machine the corners as much as possible. If you want to machine more corners, you can use a narrower end mill.
I have attached the file for your reference.
