mattdlr89
in reply to: jscott6SWZG
You need to have an open contour selection and just select the undercut edge. Then use extensions so your tool is clear when it comes in and out.
Do this by holding down alt when you select a line, or with the new contour selection there is an "open" contours button".
I've attached the updated file.
