serge.quiblier
in reply to: jwmodel
Hi @jwmodel
This is not very complicated, you just had to edit the post using a text editor.
(Notepad, notepad++... but not Word and alike)
Then change this code
  optionalStop: true, // optional stop
  isnc: true, // specifies the mode ISNC (ISO NC mode) or BNC (Basic NC mode)
  separateWordsWithSpace: true, // specifies that the words should be separated with a white space
into that code
  isnc: false, // specifies the mode ISNC (ISO NC mode) or BNC (Basic NC mode)
Or else, just changing it once at posting time, to test, then edit the post if the code run successfully.
Cheers
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
