02-20-2023
06:27 AM
- Mute
- Permalink
- Report
02-20-2023
06:27 AM
Not sure the best way to explain how I do it other than sharing a screenshot of my library tree and the layout I use for endmills. Depends on the range of tools/materials you work on it can be as simple or as complex as you want it to be.. This layout works the best for me and the couple of guys that help me with programming and most of this info carries over to my setup sheets so finding tools out in the crib is pretty easy. Best practice is to find something that works and be diligent to stick to it, sometimes it seems like it takes too much time to setup the correct information for a tool or preset but if you keep it consistent and accurate it will benefit you down the road.
Please click "Accept Solution" if I helped with your question or issue.
Fusion
