- Mute
- Permalink
- Report
I had a big response typed up, but I forgot to submit it, and it gave me an error when I went to submit it later, so I lost it.
Anyway, polar milling and non-polar milling are both correct with keep relay 23.7 set to a 0. That just means that I have to check the box for reverse spindle on the sub to spin the correct direction for turning tools that are defined correctly. It would be nice to have the functionality of inverting the C axis rotation on the sub for both polar and non-polar milling so that the keep relay does not have to be messed with for guys with machines that have it set to a 1 by default, because that's how my machine was setup from the factory, and it was a hassle to get sorted to begin with.
If that would work, I could flip the keep relay back, uncheck the reverse spindle box, and all would work as intended with the default post settings.
Fusion
