programming2C78B
177 Views, 1 Reply
Drill op no longer shows Chipload
setup; 6mm drill, 150sfm/2500rpm at .007ipr/17.5ipm
Not sure Im a fan of this new forced change! I shouldn't have to NOW also get a feed rate calculator to program my drills after 7+ years of F360 CAM.
I don't want to program retract in IPR, and I don't want to swap all my Drill feeds into IPR. For the mill, I program all drills off of a fixed SFM and IPM that makes every drill in the world function properly (ie 35sfm, F2.2 for stainless. This auto-generates an ever increasingly large chipload based on the tool dia)
Another issue is it doesn't auto calculate a unit switch! For instance, I can set it to 20ipm but if I click it to IPR it will say whatever it wants - not the equivalent value that is 20ipm (which at 2500rpm should be .008ipr)
If I go into Show Toolpath Data for this op, it also says it has a feed of 0, and in simulation shows .008" ipr.
Please click "Accept Solution" if what I wrote solved your issue!
We've heard this feedback from many users, and we are working on improving this dialog. We are sorry for the inconvenience, hopefully it's short lived...
Seth Madore
