Why it's failing to post, I'm not sure. I think the..."flaw"...in your process is simply having the combination of "Multiple Depths" roughing passes AND the Ramp style entrance selected. If you are going to use Ramp, you don't need to specify Multiple Depths at all. Simply give it a large Ramp Angle and then specify Max Ramp Stepdown to what you would want to see (I chose .125" for instance)
It posted out just fine for me with that choice. Move away from choosing both options. Multiple depths are fine to select if you are dropping into a pre-drilled hole and then going from there in a simple 2 axis contour operation.
If you are going to ramp down the entire contour, just turn off multiple depths. Just make sure your Heights tabs are set proper
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
