warnerwerkswv
in reply to: seth.madore
My machine currently turns toward the operator with an M3, which I had to change keep relay 23.7 to get milling correct on the sub. If I change it back, which is what I want to do to be able to define my tools correctly, milling is inverted. Therefore, I need to be able to invert the axes to correct it.
I'll post the code with the box checked and unchecked (which is the same. It does not change).
