warnerwerkswv
933 Views, 21 Replies
Doosan Mill-Turn Fanuc Post does not invert AC axes on sub when box is checked
As the title says, the "Invert AC Axes on sub-spindle" function does not work on this post. Not sure why, but I've asked quite a few other people, and it just does not work.
This causes us all to have to define tools backwards (LH/RH, CW/CCW) in the tool library to get them to spin correctly on the sub side because keep relay 23.7 has to be a 0 to get milling correct on the sub side. If that weren't the case, all of those issue would be solved.
