02-16-2023
05:44 AM
- Mute
- Permalink
- Report
02-16-2023
05:44 AM
Thanks for reporting this @DarthBane55.
I would not expect the extensions to work on this strategy because it does NOT machine the curves directly, but rather, uses the curves to select model edges. So extensions will not have the desired effect. That said, the strategy does support 'Tangential Fragment Extension Distance' (Passes tab), which should actually extend the toolpath.
However, you're absolutely right to point out that when the user is manually selecting edges to deburr, we shouldn't be offering parameters to extend the curve when we know they're not going to have the intended effect. We'll look at this.
Peter Lockyer
Software Development Manager, Fusion 360 Manufacturing and PowerMill
Fusion
