isamiBDSPX
314 Views, 3 Replies
Post processor help: How to get WCS origin's X, Y and Z values
Hi everyone!
I'm having a little bit of trouble getting my post processor to write a simple line of code like:
G10 L2 P1 X0. Y0. Z-381.926 (G54 WCS)
That line, on a Fanuc control will set the G54 WCS.
In the part I'm working right now, the WCS origin on my setup is set at (X=0, Y=0, Z=-381.926)
When I dump the information I can get this:
currentSection.fcsOrigin=(1.7859e-13, 1.10939e-13, 381.926)
which are the X, Y and Z values that I'm looking for, well sort of.
I have three problems:
 1. I don't know how to access the individual values.
 2. Even though my WCS origin is at X=0 and Y=0, I get a scientific notation of a number that's very close to zero but not exactly zero (X= 1.7859e-13, Y= 1.10939e-13).
 3. I always get the values inverted. What I mean is that they are presented as if they are multiplied by -1. Why?
Any ideas on how to get my post to write this line of code?
G10 L2 P1 will always be the same, but the X, Y and Z coordinates will change whenever I change the WCS origin.
Thanks in advance.
Best,
Isami
seth.madore
in reply to: isamiBDSPX
Is it ALWAYS that same exact line of code?
Seth Madore
isamiBDSPX
in reply to: seth.madore
G10L2P1 is always the same
but the X,Y and Z values depend on where I've established my WCS origin which changes on every part.
isamiBDSPX
I've found the solution. Once I've discovered the WCS is stored in a Vector Object everything was very straight forward.
This is the code I needed:
  var setupWCSorigin = getSection(0).fcsOrigin.negated;
  var setupWCS = getSection(0).workOffset;
  gAbsIncModal.reset();
  writeBlock(
    gAbsIncModal.format(90),
    gFormat.format(10),
    "L2P" + (1 + setupWCS),
    "X"+xyzFormat.format(setupWCSorigin.x),
    "Y"+xyzFormat.format(setupWCSorigin.y),
    "Z"+xyzFormat.format(setupWCSorigin.z),
    formatComment("G" + (54 + setupWCS) + " WCS")
  writeBlock(gFormat.format(11));
 The vector object logically has the x, y and z attributes, problem 1 solved.
 xyzFormat takes care of the scientific notation, problem 2 solved.
The vector object also has the negated attribute which, as its name implies, gives you the negated vector, problem 3 solved
With that code, on a FANUC control, I can have the program update automatically the WCS.
For example:
G90 G10 L2 P2 X56. Y-284. Z-395.926 (G55 WCS)
This will update the G55 WCS to those coordinates which is the origin of my Setup. You can update other WCS changing the P value. (P1 = G54, P2 = G55, P3 = G56, P4 = G57, P5 = G58, P6 = G59)
I found this very useful to have a relatively accurate position of the WCS before probing the part to have the exact location of the WCS.
Hope this can help others!
Cheers,
Isami
