m_lamarca
in reply to: seth.madore
  • I have not tried/seen that deburr option. Not exactly what I am looking for, think of machining outside of a box, and rounding all those outside corners while running the endmill around it, without modifying the model. Or, turning, just run a simple .005 or .010 radius on all outside corners.
    Currently trying to do that on a hex, on a mill turn, and not having any luck.
    As for limitations, I seem to not be able to get the tool paths I am looking for. Instead of simple g2/g3, i am getting g1 lines. Yet, in the rough pass, it does give circular interpolation. Yesterday, I couldn’t get system to “chain” and outside profile for milling. Ended up using trig and a calculator to figure out intersect points and add that in manually. Models with edge breaks, versus models without, I am always fat fingering the numbers the cam comes up with.
    Again, new to F360, and not impressed at all. Seriously considering buying my boss BobCam.
