serge.quiblier
in reply to: f_feroglu
Hi @f_feroglu
No, the behavior is still the same.
When the toolpath is generated by Fusion, it is created from the solid, or from an edge that is wrapped on the cylinder like that one :
But to use tracyl or any similar function like G107, you must have the unwrapped curve, i.e., that one:
The flattened curve is currently not created by Fusion, so it cannot be passed to the post engine.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
