prp2k17
398 Views, 1 Reply
Machining Features using rotary axis option
Iam trying to machine this STL using rotary axis milling.
For rotary axis milling: Fusion is generating Gcode in YZA axis.
This means that the spindle does not move in X axis and always stays at pos1
( moves only in Z, not in X).
But feature F1 shown in this STL cannot be machined if spindle stays put at pos1.
However if spindle is allowed to move in X, then it can reach pos2, where it can indeed machine the feature F1.
So the question is : Is there any setting in Fusion to generate gcode for rotary axis milling, which allows X axis motion and gcode output is in XYZA axis ?
STL image and briefing
