Are you using the supplied generic Haas pre-NGC post, or one that you've modified to suit your needs?
If it's modified, could you share it here?
Also, could you share a sample Fusion file that is giving you this issue?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
