HughesTooling
in reply to: j.cavender
Make sure you setup using the code in post #9, I experimented a bit and ended up with 0.01 in the code, if you're using inches that will be a problem.
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
Spiraltolerance  = spatial(0.025, MM);
Mark
Mark Hughes
Owner, Hughes Tooling
